[GRASS-dev] Re: About the vector changes
Markus Metz markus.metz.giswork at googlemail.com
Sat Aug 8 15:00:27 EDT 2009
>>> Ah, ok, you use the grass57 dataset. I have now changed the version
>>> number and compatibility info, you should now get reasonable
>>> warnings/errors with the spearfish57 dataset.
>> Okay, I'll check it.
> Nope. As of r38644, the error message is unchanged.
I got the order of the checks wrong. First check must be version check,
only after that comes the check for file size. That LFS check is there
to check if sizeof(off_t) = 8 is needed to read the sidx file. Fixed in
r36845.
Markus M
