[GRASS-dev] Re: About the vector changes
Thu Aug 13 19:38:21 EDT 2009
Markus Metz wrote:
> >>>> I got carried away (replacing all fseek/ftell occurrences I could find
> >>>> with G_fseek/G_ftell, adjusting off_t as you showed above) and also made
> >>>> r3.in|out.v5d LFS-safe, but did not submit. Should I?
> >>> Yes; ideally, we should use G_{fseek,ftell} everywhere.
> >> Patch attached.
> > I've committed this (with fixes) as r38703.
> Do the Makefiles for the modules also need fixing with
> ifneq ($(USE_LARGEFILES),)
> EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
> endif
> or is -D_FILE_OFFSET_BITS=64 now set globally in COMPILE_FLAGS and
> COMPILE_FLAGS_XX or similar?
Ultimately, it will be set globally, but we need to ensure that
everything can handle it before turning it on.
I originally thought that it should be set in config.h, but that would
require every file to include <grass/config.h> before including
<stdio.h>. Setting it in the compiler switches will be more robust.
