[GRASS-dev] v.in.gshhs v2.0 error reading data
Markus Metz markus.metz.giswork at googlemail.com
Fri Aug 14 12:56:22 EDT 2009
I've updated v.in.gshhs, it supports now GSHHS data versions 1.4 through
to 2.0, and issues an error if a version is not supported, telling
exactly that, no more non-descript error reading data.
v.in.gshhs imports exported as shapefiles display now properly in QGIS,
no more strange horizontal lines.
Please check out the new version and let me know if it doesn't work for you.
Markus M
Jamie Adams wrote:
> I grabbed the 2.0 version of gshhs, released 2009-07-15, but can't
> import it into GRASS.  The module doesn't return much in terms of
> error information.
> v.in.gshhs in=gshhs_f.b out=gshhs_f --o
> Using lat/lon bounds N=90.000000 S=-90.000000 E=180.000000 W=-180.000000
> ERROR: Error reading data
> I've tried the various levels of detail (f, h, i, l) with the same
> result.  Based on the readme file there may be some internal changes,
> but these are beyond me.  Any thoughts?
> - Jamie
> GSHHS 2.0 - http://www.soest.hawaii.edu/pwessel/gshhs/index.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
