[GRASS-dev] v.in.gshhs v2.0 error reading data
Jamie Adams
jaadfoo at gmail.com
Fri Aug 14 14:30:27 EDT 2009
That did the trick, thanks for the quick update!
- Jamie
On Fri, Aug 14, 2009 at 9:56 AM, Markus Metz <
markus.metz.giswork at googlemail.com> wrote:
> Hi,
> I've updated v.in.gshhs, it supports now GSHHS data versions 1.4 through to
> 2.0, and issues an error if a version is not supported, telling exactly
> that, no more non-descript error reading data.
> v.in.gshhs imports exported as shapefiles display now properly in QGIS, no
> more strange horizontal lines.
> Please check out the new version and let me know if it doesn't work for
> you.
> Markus M
> Jamie Adams wrote:
>> I grabbed the 2.0 version of gshhs, released 2009-07-15, but can't import
>> it into GRASS. The module doesn't return much in terms of error
>> information.
>> v.in.gshhs in=gshhs_f.b out=gshhs_f --o
>> Using lat/lon bounds N=90.000000 S=-90.000000 E=180.000000 W=-180.000000
>> ERROR: Error reading data
>> I've tried the various levels of detail (f, h, i, l) with the same result.
>> Based on the readme file there may be some internal changes, but these are
>> beyond me. Any thoughts?
>> - Jamie
>> GSHHS 2.0 - http://www.soest.hawaii.edu/pwessel/gshhs/index.html
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090814/7027256b/attachment.html
