[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
GRASS GIS trac at osgeo.org
Fri Aug 14 22:29:37 EDT 2009
  Reporter:  kyngchaos  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  normal     |   Milestone:  6.4.0
 Component:  Raster     |     Version:  6.4.0 RCs
Resolution:             |    Keywords:  r.li
  Platform:  All        |         Cpu:  All
Comment (by glynn):
 Replying to [comment:8 neteler]:
 > As mentioned above, the path should NOT be set. conf= has to be a
 filename, not a full pathname.
 > Please always post the command line to better illustrate the problem
 (also in GUI mode available)
 > @devs: can we simply strip off the directory stuff?
 It would be better to only prepend ~/.r.li/ if the filename isn't an
 absolute path (see G_is_absolute_path()), or possibly if it doesn't
 contain any directory separators.
 AFAIK, the GUI will see "old_file" in the ->gisprompt field and provide an
 absolute pathname. Either the ->gisprompt field needs to be removed (so
 it's just a string option), or the code needs to be changed to allow an
 absolute pathname. Or it could enumerate ~/.r.li/ and add all files found
 therein to the ->options field.
 Certainly, it shouldn't silently discard any directory components; that
 would leave the user trying to figure out why it isn't behaving as
 expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:12>
