[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
trac at osgeo.org
Fri Aug 14 22:45:43 EDT 2009
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.li
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:11 hamish]:
> One thing it may be, that I haven't tried is if GRASS is built without
the gcc -g debugging flag. I always build with that and AFAIU that means
all variables are initizalied to '\0' (null).
No. Static variables (global variables and local variables with the
"static" qualifier") without an explicit initialiser are implicitly
initialised to zero regardless of the compiler options used. This
behaviour is mandated by the C standards. A static variable's initial
value is stored in the binary, so it isn't possible for a static variable
to be uninitialised.
[However, variables which are initialised to zero, explicitly or
implicitly, are all stored in the BSS segment. As the entire segment
contains only zeros, it can be "compressed" to nothing. Nonetheless,
everything within that segment is initialised to zero at startup.]
Automatic variables (local variables lacking the "static" qualifier)
without an explicit initialiser are normally uninitialised; I have seen
compilers which will initialise such variables (not necessarily to zero)
in debug mode, but I've never seen gcc do it (gcc's -g switch controls
whether or not debug info is added to the output file; it doesn't affect
code generation in any way, unlike e.g. MSVC where "debug mode" disables
optimisation by default).
Also, enabling or disabling optimisations may affect what happens to be
stored in a particular section of uninitialised memory, even if it doesn't
affect whether or not initialisation occurs.
However:
> If there is a test that some empty variable == NULL, such as
r.li.daemon/worker.c's {{{ if (ad->mask_name == NULL) { }}}, and that
variable is not explicitly made empty upon creation and then used
uninitialized.... well, it's a theory.
ad is a pointer to a structure which is allocated with G_malloc(). This
uses malloc, which doesn't normally initialise memory (although, again,
some implementations will initialise malloc()d memory in debug mode, but
not usually to zero).
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:13>
