[GRASS-dev] Re: [GRASS-windows] No such file or dire
Peter Brooks peter at timedworld.com
Sat Aug 15 09:45:41 EDT 2009
------- Forwarded message follows -------
The 'About' window says
GRASS GIS 6.4.0svn (2009)
GIS Library Revision 37101 (2009-05-10)
I downloaded and installed on 02-Aug.
Cheers
Peter
On 14 Aug 2009 at 16:54, Hamish wrote:
> [r.in.poly fails to read text input file on Windows/CMD line]
I have checked at the r.in.poly source code, the problem does
not seem to be there. The path is passed to fopen() verbatim.
what version/revision of 6.4.0svn is this? is it the latest?
ISTR that Martin&Glynn had fixed this -- wxGUI now uses a
python parser which understands shell quoting on the Cmd> line.
But that might only be present in the very latest build.
Hamish
grass-windows mailing list
grass-windows at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-windows
------- End of forwarded message -------
