[GRASS-dev] [GRASS GIS] #731: Warming message after removing layer confusing
GRASS GIS trac at osgeo.org
Mon Aug 24 04:43:05 EDT 2009
 Reporter:  pvanbosgeo               |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  6.4.0
Component:  default                  |     Version:  svn-develbranch6
 Keywords:  remove, delete, message  |    Platform:  Linux
      Cpu:  x86-64                   |
 I am not sure this is a bug or I am just not following the logic of the
 message, but:
 suppose I have both in mapset 'climate' and 'climpred' a layer prec_8.
 When deleting the layer 'prec_8' from mapset 'climpred' I get the
 following message:
 quote>
 Removing raster <prec_an>
 cell/prec_8' was found in more mapsets (also found in <climpred>)
 Using <prec_an at climate>
 <unquoute
 For me this is confusing as it seems to tell that the layer prec_8 is
 deleted from the wrong mapset (which is not the case). If the message is
 correct, would it mean that after deleting the layer subsequent actions
 using layer prec_8 will take that layer from the mapset climate?? If so I
 would suggest to rewrite that message to something like:
 quote>
 Another laye with the name prec_8 exists in mapset <climate>
 Removed prec_8 at climpred
 <quote
 Such a message would be more in line with the (rather straightforward and
 clear) message one gets when using a layer in r.mapcalc while a layer with
 the same name exists in another mapset.
 Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/731>
