[GRASS-dev] [GRASS GIS] #735: r.in.wms causes g.parser buffer owerflow
GRASS GIS trac at osgeo.org
Tue Aug 25 09:44:22 EDT 2009
 Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.5.0
Component:  Raster       |     Version:  svn-develbranch6
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 I used r.in.wms to download high resolution topographical maps from local
 WMS service. Download part went just fine but it resulted into 287 tiles.
 Then r.in.wms calls r.in.gdalwarp
 input=/home/maris/grassdata/wms_download/topo_10k_psrs_0.png and so on 287
 tile names. Such call results in buffer owerflow in g.parser:
 *** buffer overflow detected ***: g.parser terminated
 ======= Backtrace: =========
 /lib/libc.so.6(__fortify_fail+0x37)[0x7f017d0107e7]
 /lib/libc.so.6[0x7f017d00e5c0]
 /lib/libc.so.6[0x7f017d00d8b9]
 /lib/libc.so.6(_IO_default_xsputn+0x85)[0x7f017cf9a935]
 /lib/libc.so.6(_IO_vfprintf+0x35b4)[0x7f017cf6e1f4]
 /lib/libc.so.6(__vsprintf_chk+0x9d)[0x7f017d00d95d]
 /lib/libc.so.6(__sprintf_chk+0x80)[0x7f017d00d8a0]
 g.parser(main+0x458)[0x401668]
 /lib/libc.so.6(__libc_start_main+0xe6)[0x7f017cf46a26]
 g.parser[0x401099]
 ======= Memory map: ========
 00400000-00403000 r-xp 00000000 08:06 10052434
 /home/maris/soft/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/g.parser
 00602000-00603000 r--p 00002000 08:06 10052434
 00603000-00604000 rw-p 00003000 08:06 10052434
 01169000-0118a000 rw-p 00000000 00:00 0
 [heap]
 7f017cb0e000-7f017cb23000 r-xp 00000000 08:02 834485
 /lib64/libgcc_s.so.1
 7f017cb23000-7f017cd22000 ---p 00015000 08:02 834485
 7f017cd22000-7f017cd23000 r--p 00014000 08:02 834485
 7f017cd23000-7f017cd24000 rw-p 00015000 08:02 834485
 7f017cd24000-7f017cd26000 r-xp 00000000 08:02 294652
 /lib64/libdl-2.10.1.so
 7f017cd26000-7f017cf26000 ---p 00002000 08:02 294652
 7f017cf26000-7f017cf27000 r--p 00002000 08:02 294652
 7f017cf27000-7f017cf28000 rw-p 00003000 08:02 294652
 7f017cf28000-7f017d079000 r-xp 00000000 08:02 294677
 /lib64/libc-2.10.1.so
 7f017d079000-7f017d279000 ---p 00151000 08:02 294677
 7f017d279000-7f017d27d000 r--p 00151000 08:02 294677
 7f017d27d000-7f017d27e000 rw-p 00155000 08:02 294677
 7f017d27e000-7f017d283000 rw-p 00000000 00:00 0
 7f017d283000-7f017d305000 r-xp 00000000 08:02 294683
 /lib64/libm-2.10.1.so
 7f017d305000-7f017d504000 ---p 00082000 08:02 294683
 7f017d504000-7f017d505000 r--p 00081000 08:02 294683
 7f017d505000-7f017d506000 rw-p 00082000 08:02 294683
 7f017d506000-7f017d51a000 r-xp 00000000 08:02 830733
 /lib64/libz.so.1.2.3
 7f017d51a000-7f017d719000 ---p 00014000 08:02 830733
 7f017d719000-7f017d71a000 r--p 00013000 08:02 830733
 7f017d71a000-7f017d71b000 rw-p 00014000 08:02 830733
 7f017d71b000-7f017d723000 r-xp 00000000 08:06 10052200
 gnu/lib/libgrass_datetime.6.5.svn.so
 7f017d723000-7f017d922000 ---p 00008000 08:06 10052200
 7f017d922000-7f017d923000 r--p 00007000 08:06 10052200
 7f017d923000-7f017d924000 rw-p 00008000 08:06 10052200
 7f017d924000-7f017d978000 r-xp 00000000 08:06 10052212
 gnu/lib/libgrass_gis.6.5.svn.so
 7f017d978000-7f017db77000 ---p 00054000 08:06 10052212
 7f017db77000-7f017db78000 r--p 00053000 08:06 10052212
 7f017db78000-7f017db7a000 rw-p 00054000 08:06 10052212
 7f017db7a000-7f017db81000 rw-p 00000000 00:00 0
 7f017db81000-7f017db9e000 r-xp 00000000 08:02 294369
 /lib64/ld-2.10.1.so
 7f017dc10000-7f017dd70000 r--p 00000000 08:02 505020
 /usr/lib64/locale/locale-archive
 7f017dd70000-7f017dd73000 rw-p 00000000 00:00 0
 7f017dd8a000-7f017dd91000 r--s 00000000 08:02 489490
 /usr/lib64/gconv/gconv-modules.cache
 7f017dd91000-7f017dd99000 r--p 00000000 08:06 10420339
 gnu/locale/lv/LC_MESSAGES/grassmods.mo
 7f017dd9a000-7f017dd9d000 rw-p 00000000 00:00 0
 7f017dd9d000-7f017dd9e000 r--p 0001c000 08:02 294369
 /lib64/ld-2.10.1.so
 7f017dd9e000-7f017dd9f000 rw-p 0001d000 08:02 294369
 /lib64/ld-2.10.1.so
 7fff55c2f000-7fff55c47000 rw-p 00000000 00:00 0
 [stack]
 7fff55cf8000-7fff55cf9000 r-xp 00000000 00:00 0
 [vdso]
 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
 [vsyscall]
 Aborted
Ticket URL: <https://trac.osgeo.org/grass/ticket/735>
