[GRASS-dev] lots of link errors in trunk (OSX)
Colin Nielsen
colin.nielsen at gmail.com
Fri Aug 28 21:47:31 EDT 2009
Errors continue in windows, starting with lib/raster.
-Colin
On Fri, Aug 28, 2009 at 8:02 PM, Glynn Clements<glynn at gclements.plus.com> wrote:
> William Kyngesburye wrote:
>> > > wrote:
>> >> Right; I committed at the point that everything built okay on my
>> >> system.
>> > I have tried again after svn update and "make distclean":
>> > It now compiles ok. Thanks for the quick fixes.
>> Still problems on OSX.
>> g.proj is still missing GDAL.
>> g.region, r.horizon, r.sun, r.sunmask, i.latlong are missing PROJ.
>> v.select is missing GEOS (GEOS is configuring for me).
> I've replaced most of the LIBES= and DEPENDENCIES= settings with data
> from the linkage database. It should fix all of the above issues,
> although it may have introduced some new ones (a total of 320
> Makefiles were modified).
> In particular, I suspect that some of them will need to have
> dependencies for ICONVLIB, INTLLIB, SOCKLIB, XDRLIB, and REGEXLIB
> added (these provide functionality which is part of GNU libc, so they
> don't show up on Linux).
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
