[GRASS-dev] RC5 on Mac OS X
    Jeshua Lacock
    jeshua at OpenOSX.com
    Sun Aug 30 07:30:09 EDT 2009
Greetings,
I just built RC5 here on Mac OS X 10.5.7 using pretty much all of the
latest available stable versions of the dependencies.
The build reports "No errors detected." However I have run into two
problems. When I launch GRASS, I get the error:
WARNING: Vector digitizer is not available (dlopen(/Library/OpenOSX/
grass/grass 6.4.0RC5/etc/wxpython/vdigit/_grass6_wxvdigit.so, 2):
Symbol not found: __ZN12wxStringBase8InitWithEPKcmm
   Referenced from: /Library/OpenOSX/grass/grass-6.4.0RC5/etc/wxpython/
   Expected in: dynamic lookup
The symbol has an address in libwx:
nm libwx_base_carbon-2.8.0.6.0.dylib | grep
0005f320 T __ZN12wxStringBase8InitWithEPKcmm
And when I attempt to launch NVIZ (by choosing "3D view" from the map
display), the GUI crashes and in the terminal reports:
dyld: lazy symbol binding failed: image not found for lazy pointer at
0x286d054
dyld: image not found for lazy pointer at 0x286d054
I built the aqua version of Tcl/Tk 8.5.7 which runs fine, installed
wxPython 2.8.10.1, numpy 1.3.0, PyOpenGL 3.0.1a3 and used the --with-
opengl=aqua flag when running configure.
Any ideas?
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 208.462.4171
