[GRASS-dev] [GRASS GIS] #737: ZBulkLabeling don't work
GRASS GIS trac at osgeo.org
Sun Aug 30 16:14:59 EDT 2009
 Reporter:  torstenosgeo   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  6.4.0
Component:  wxGUI          |     Version:  unspecified
 Keywords:  ZBulkLabeling  |    Platform:  Linux
      Cpu:  x86-32         |
 Hallo,
 I try to digitize isolines with grass6.4 and wxpython-gui. After the
 digitzing I see nothing in the attribut table and get following in the
 command output:
 (Sat Aug 29 21:55:29 2009)
 g.manual -i
 Starting browser <x-www-browser> for module index...
 Install the acroread-l10n-de package if you want acroread in
 German.
 ** Message: GetValue variable 1 (1)
 ** Message: GetValue variable 2 (2)
 Vector digitizer settings saved to file </home/torsten/.grasswx6>.
   File
 "/usr/lib/grass64/etc/wxpython/gui_modules/mapdisp.py", line
 1083, in MouseActions
 self.OnLeftDown(event)
   File
 1415, in OnLeftDown
 self.DrawLines(self.pdcTmp, begin, end)
 TypeError
 DrawLines() takes at most 3 arguments (4 given)
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
 1107, in MouseActions
 self.OnRightUp(event)
   File
 1966, in OnRightUp
 if digitClass.ZBulkLine(pos1, pos2, dlg.value.GetValue(),
 AttributeError
 Digit instance has no attribute 'ZBulkLine'
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
   File
   File
 1415, in OnLeftDown
 TypeError
   File
   File
 1966, in OnRightUp
 AttributeError
Ticket URL: <http://trac.osgeo.org/grass/ticket/737>
