[GRASS-dev] GUI feedback
Martin Landa
landa.martin at gmail.com
Thu Dec 10 03:58:01 EST 2009
2009/12/10 Tim Michelsen <timmichelsen at gmx-topmail.de>:
> * What is the "Search" field above the "CMD>" for? It doesn't effect
> anything here.
You can search modules based description or keywords. Try to type
'buffer', <tab><tab>, right arrow and you get a list of selected
modules.
> * The self completing command line is kicking. I could imagine to see
> all options of a command when typing it's name but greyed out. When
> continue typing, they could become active.
Right, or the complete command could be printed to statusbar.
> * the completion does at times need a ' ' after the '='
> * d.zoom map=elevation_shade does not zoom to the layer extends.
d.zoom works only with X monitors.
> * after adding a new layer group and selecting it, the next layer does
> not get automatically added to that group.
It's a bug. Please report it.
> only after a layer is shifted in the group and selected, the next layer
> will be put into the group.
> * There are numerous dialogs which still require to enter the layer name
> manually instead of selecting from a list (g.region, r.region).
? E.g. 'rast' parameter enables selecting raster map... ?
> * as pointed out by the shell geeks, selection of layers from a
> location/mapset with many layers could be more effective. Maybe a
> incremental search would help.
Yes.
> * Grass Extension manager (Very nice idea!!!) cannot install due to make
> errors.
Do you mean gem or g.extension?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
