[GRASS-dev] Re: [GRASS GIS] #837: Memory leaks in r.example
trac at osgeo.org
Tue Dec 15 22:18:12 EST 2009
Reporter: sprice | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Resolution: wontfix | Keywords:
Platform: MacOSX | Cpu: OSX/Intel
Changes (by glynn):
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [ticket:837 sprice]:
> In r.example, there are many small memory leaks in basic functions.
We don't care about "fixed" memory consumption, i.e. the use of a certain
amount of memory for the process overall, or for each library, or for each
map. It's only considered a "leak" if the memory usage will grow during
normal processing, i.e. consuming memory (unnecessarily) per raster row,
or per vector element.
If you try to use the GRASS libraries from a persistent application (one
which performs an unlimited number of operations until it is explicitly
terminated), you lose. The libraries weren't designed for that purpose,
aren't suitable for that purpose, and will probably never be suitable for
that purpose. And memory usage is the least of the issues.
Closing as "wontfix". If you have details of any actual '''leaks''', feel
free to reopen.
Ticket URL: <http://trac.osgeo.org/grass/ticket/837#comment:2>
