[GRASS-dev] Re: [GRASS GIS] #837: Memory leaks in r.example
trac at osgeo.org
Wed Dec 16 02:10:13 EST 2009
Reporter: sprice | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Resolution: | Keywords:
Platform: MacOSX | Cpu: OSX/Intel
Changes (by sprice):
* status: closed => reopened
* resolution: wontfix =>
Comment:
Judging by the 1616 leaked nodes in get_map_row() this is on a per row
basis. But I've never heard of a well written program containing leaks
anyway.
Here's your fix for the first leak:
Change line 58 in lib/gis/gisinit.c from "G_location_path();" to
"G_free(G_location_path());"
The second leak:
Add "G_free(dummy);" at line 1003 in file lib/gis/get_row.c
The third, fourth, & last leaks (in lib/gis/opencell.c) are a bit more
difficult to take care of all permutations:
--- grass-6.4.0RC5/lib/gis/opencell.c 2009-03-04 01:06:31.000000000
-0700
+++ grass-6.4.svn_src_snapshot_2009_12_12/lib/gis/opencell.c 2009-12-16
00:04:45.000000000 -0700
@@ -188,21 +188,27 @@
G_warning(_("Unable to open raster map <%s@%s> since it is a
reclass "
"of raster map <%s@%s> which does not exist"),
name, mapset, r_name, r_mapset);
+ G_free(xmapset);
return -1;
break;
default: /* Error reading cellhd/reclass file */
+ G_free(xmapset);
return -1;
/* read the cell header */
- if (G_get_cellhd(r_name, r_mapset, &cellhd) < 0)
- return -1;
+ if (G_get_cellhd(r_name, r_mapset, &cellhd) < 0){
+ G_free(xmapset);
+ return -1;
/* now check the type */
MAP_TYPE = G_raster_map_type(r_name, r_mapset);
- if (MAP_TYPE < 0)
- return -1;
+ if (MAP_TYPE < 0){
+ G_free(xmapset);
+ return -1;
if (MAP_TYPE == CELL_TYPE)
/* set the number of bytes for CELL map */
@@ -211,6 +217,7 @@
if (CELL_nbytes < 1) {
G_warning(_("Raster map <%s@%s>: format field in header file
invalid"),
r_name, r_mapset);
+ G_free(xmapset);
return -1;
@@ -220,11 +227,13 @@
"Found raster map <%s@%s>, should be <%s>."),
name, mapset, name, G__projection_name(cellhd.proj),
G__projection_name(G__.window.proj));
+ G_free(xmapset);
return -1;
if (cellhd.zone != G__.window.zone) {
G_warning(_("Raster map <%s@%s> is in different zone (%d) than
current region (%d)"),
name, mapset, cellhd.zone, G__.window.zone);
+ G_free(xmapset);
return -1;
@@ -232,6 +241,7 @@
if (MAP_TYPE == CELL_TYPE && (unsigned int) CELL_nbytes >
sizeof(CELL)) {
G_warning(_("Raster map <%s@%s>: bytes per cell (%d) too large"),
name, mapset, CELL_nbytes);
+ G_free(xmapset);
return -1;
@@ -261,6 +271,7 @@
#else
G_warning(_("map <%s@%s> is a GDAL link but GRASS is compiled
without GDAL support"),
r_name, r_mapset);
+ G_free(xmapset);
return -1;
#endif
@@ -268,8 +279,10 @@
/* now actually open file for reading */
fd = G_open_old(cell_dir, r_name, r_mapset);
- if (fd < 0)
- return -1;
+ if (fd < 0){
+ G_free(xmapset);
+ return -1;
fcb = new_fileinfo(fd);
@@ -298,6 +311,7 @@
fcb->name = G_store(name);
fcb->mapset = G_store(mapset);
+ G_free(xmapset);
/* mark no data row in memory */
fcb->cur_row = -1;
@@ -977,9 +991,12 @@
return -1;
G__file_name(path, "fcell", name, xmapset);
- if (access(path, 0) == 0)
- return 1;
+ if (access(path, 0) == 0){
+ G_free(xmapset);
+ return 1;
G__file_name(path, "g3dcell", name, xmapset);
+ G_free(xmapset);
return 1;
@@ -1002,7 +1019,8 @@
char path[GPATH_MAX];
const char *xmapset;
+ RASTER_MAP_TYPE cktype;
xmapset = G_find_cell2(name, mapset);
if (!xmapset) {
if (mapset && *mapset)
@@ -1013,11 +1031,15 @@
- return G__check_fp_type(name, xmapset);
+ if (access(path, 0) == 0) {
+ cktype = G__check_fp_type(name, xmapset);
+ G_free(xmapset);
+ return cktype;
+ G_free(xmapset);
return DCELL_TYPE;
The next leak in lib/gis/gdal.c:
@@ -135,12 +139,14 @@
RASTER_MAP_TYPE map_type;
FILE *fp;
struct Key_Value *key_val;
- const char *p;
+ const char *p, *fc;
DCELL null_val;
- if (!G_find_cell2(name, mapset))
+ if (!(fc = G_find_cell2(name, mapset)))
return NULL;
+ G_free(fc);
map_type = G_raster_map_type(name, mapset);
if (map_type < 0)
return NULL;
Ticket URL: <http://trac.osgeo.org/grass/ticket/837#comment:3>
