[GRASS-dev] Re: grass-dev Digest, Vol 44, Issue 44
Michael Barton michael.barton at asu.edu
Thu Dec 17 09:25:54 EST 2009
On Dec 16, 2009, at 6:55 PM, grass-dev-request at lists.osgeo.org wrote:
> Date: Wed, 16 Dec 2009 21:15:59 +0100
> From: Tim Michelsen <timmichelsen at gmx-topmail.de>
> Subject: [GRASS-dev] Re: a better console and better diff
> To: grass-dev at lists.osgeo.org
> Message-ID: <hgbf60$mmv$1 at ger.gmane.org>
> Content-Type: text/plain; charset=ISO-8859-1
>>> I personally don't mind separate input and output windows.
> -1
> I would like to see:
> 1 Tab for the layer manager, 2dn tab for the command window.
We already have that.
> Maybe there could be the option to optionally redirect the output into a
> text file in
> /tmp/grass.log?
The command output window already has a save to text button
Have you tried the wxpython GUI?
Michael
>> I think that separate windows make more sense, but it's worth allowing
>> the input window to be a multi-line field with line-wrap and vertical
>> scrolling, rather than a single-line field with horizontal scrolling.
>> The latter can be annoying when entering long commands.
> +1
