[GRASS-dev] Re: [GRASS GIS] #839: wxGUI: About GRASS menu item broken
GRASS GIS trac at osgeo.org
Thu Dec 17 21:16:01 EST 2009
  Reporter:  hamish  |       Owner:  martinl
      Type:  defect  |      Status:  assigned
  Priority:  major   |   Milestone:  6.5.0
 Component:  wxGUI   |     Version:  svn-develbranch6
Resolution:          |    Keywords:
  Platform:  Linux   |         Cpu:  x86-64
Comment (by hamish):
 Martin:
 > Right, hopefully fixed in r40034.
 nice, it now launches.
 still todo:
  - the stuttering effect is still quite bad for all scrolling pages,
 leaving garbage in its wake for the new .csv tabs only. see attached
 screenshot
  - you'll notice in that screenshot that the Translators tab is missing.
 if the widget used to make the tabs doesn't have <- arrows -> to move onto
 extra tabs, the only thing I can think of is to make the default window
 size a bit wider. On this one machine it has to be 600px wide for all tabs
 to display. I think on the other machine I tried it on the number was
 about 640px. I guess it depends on local font size.
  - the version screen should come up first when you open the window, not
 the translators list.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:9>
