[GRASS-dev] Re: [GRASS GIS] #839: wxGUI: About GRASS menu item
broken
trac at osgeo.org
Sat Dec 19 06:32:54 EST 2009
#839: wxGUI: About GRASS menu item broken
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by martinl):
Replying to [comment:9 hamish]:
> still todo:
> - the stuttering effect is still quite bad for all scrolling pages,
leaving garbage in its wake for the new .csv tabs only. see attached
screenshot
It's seems to be a wxPython bug.
> - you'll notice in that screenshot that the Translators tab is missing.
if the widget used to make the tabs doesn't have <- arrows -> to move onto
extra tabs, the only thing I can think of is to make the default window
size a bit wider. On this one machine it has to be 600px wide for all tabs
to display. I think on the other machine I tried it on the number was
about 640px. I guess it depends on local font size.
done in r40056.
> - the version screen should come up first when you open the window, not
the translators list.
should be done automatically, in r40057 is called {{{SetSelection}}}
explicitly.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/839#comment:10>
