[GRASS-dev] Secret to compiling GRASS 7 on Ubuntu 9.10?
Isaac Ullah
isaac.ullah at asu.edu
Fri Dec 18 15:44:07 EST 2009
Thanks for the ideas. My ld.config.so only has one line: "include
/etc/ld.so.conf.d/*.conf" . What else should it have? Can I just add "
/usr/lib64" as a line? What would be the syntax? I ran ldconfig, and then
tried again (make clean, make, make install), but it still does not work.
Output of strace g.region -p is:
GRASS 7.0.svn (jordan_wgs84):~/grass_7_source/grass_trunk > strace g.region
-p
execve("/usr/local/grass7.0.svn-28_11_2009/bin/g.region", ["g.region",
"-p"], [/* 53 vars */]) = 0
[ Process PID=27695 runs in 32 bit mode. ]
brk(0) = 0xa03f000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or
directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =
0xfffffffff77a6000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or
directory)
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/sse2/cmov/libgrass_gproj.so",
O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/sse2/cmov",
0xffd57808) = -1 ENOENT (No such file or directory)
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/sse2/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/sse2", 0xffd57808) =
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/cmov", 0xffd57808) =
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/i686", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/sse2/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/sse2/cmov", 0xffd57808) =
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/sse2/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/sse2", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls/cmov", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/tls/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/tls", 0xffd57808) = -1 ENOENT
open("/usr/local/grass7.0.svn-28_11_2009/lib/i686/sse2/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/i686/sse2/cmov", 0xffd57808)
open("/usr/local/grass7.0.svn-28_11_2009/lib/i686/sse2/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/i686/sse2", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/i686/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/i686/cmov", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/i686/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/i686", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/sse2/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/sse2/cmov", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/sse2/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/sse2", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/cmov/libgrass_gproj.so",
stat64("/usr/local/grass7.0.svn-28_11_2009/lib/cmov", 0xffd57808) = -1
open("/usr/local/grass7.0.svn-28_11_2009/lib/libgrass_gproj.so", O_RDONLY) =
3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\354\30\0\0004\0\0\0"...,
512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=58884, ...}) = 0
mmap2(NULL, 35252, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0xfffffffff779d000
mmap2(0xf77a5000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7) = 0xfffffffff77a5000
close(3) = 0
open("/usr/local/grass7.0.svn-28_11_2009/lib/libgrass_vector.so", O_RDONLY)
= 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\250\243\0\0004\0\0\0"...,
512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=987215, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =
0xfffffffff779c000
mmap2(NULL, 289988, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0xfffffffff7755000
mmap2(0xf779a000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x45) = 0xfffffffff779a000
mmap2(0xf779b000, 3268, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xfffffffff779b000
close(3) = 0
open("/usr/local/grass7.0.svn-28_11_2009/lib/libgrass_g3d.so", O_RDONLY) = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\34X\0\0004\0\0\0"..., 512)
= 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=309592, ...}) = 0
mmap2(NULL, 124880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0xfffffffff7736000
mmap2(0xf7754000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e) = 0xfffffffff7754000
close(3) = 0
open("/usr/local/grass7.0.svn-28_11_2009/lib/libgrass_raster.so", O_RDONLY)
= 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260n\0\0004\0\0\0"..., 512)
= 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=428819, ...}) = 0
mmap2(NULL, 150788, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0xfffffffff7711000
mmap2(0xf7735000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24) = 0xfffffffff7735000
close(3) = 0
open("/usr/local/grass7.0.svn-28_11_2009/lib/libgrass_gis.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0pv\0\0004\0\0\0"...,
512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=505081, ...}) = 0
mmap2(NULL, 201120, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0xfffffffff76df000
mmap2(0xf770f000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2f) = 0xfffffffff770f000
mmap2(0xf7710000, 416, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xfffffffff7710000
close(3) = 0
open("/usr/local/grass7.0.svn-28_11_2009/lib/libm.so.6", O_RDONLY) = -1
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=147519, ...}) = 0
mmap2(NULL, 147519, PROT_READ, MAP_PRIVATE, 3, 0) = 0xfffffffff76ba000
close(3) = 0
directory)
open("/lib32/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`4\0\0004\0\0\0"...,
512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=149392, ...}) = 0
mmap2(NULL, 151680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0xfffffffff7694000
mmap2(0xf76b8000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23) = 0xfffffffff76b8000
close(3) = 0
open("/usr/local/grass7.0.svn-28_11_2009/lib/libproj.so.0", O_RDONLY) = -1
directory)
open("/lib32/tls/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib32/tls/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib32/tls/i686/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib32/tls/i686/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/tls/i686", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib32/tls/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/tls/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/tls/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/tls/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/tls", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib32/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/i686/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/i686/cmov", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/lib32/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/i686", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/lib32/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib32/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib32", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0
open("/usr/lib32/tls/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/usr/lib32/tls/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib32/tls/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib32/tls/i686/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/tls/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib32/tls/i686/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/tls/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file
or directory)
stat64("/usr/lib32/tls/i686", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/tls/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib32/tls/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/tls/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file
or directory)
stat64("/usr/lib32/tls/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/tls/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file
or directory)
stat64("/usr/lib32/tls/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/tls/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib32/tls", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/usr/lib32/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib32/i686/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib32/i686/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib32/i686", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib32/sse2/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib32/sse2", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib32/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib32/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib32/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib32", {st_mode=S_IFDIR|0755, st_size=69632, ...}) = 0
open("/lib/i486-linux-gnu/tls/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1
stat64("/lib/i486-linux-gnu/tls/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No
open("/lib/i486-linux-gnu/tls/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/lib/i486-linux-gnu/tls/i686/sse2", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/lib/i486-linux-gnu/tls/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/lib/i486-linux-gnu/tls/i686/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/lib/i486-linux-gnu/tls/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib/i486-linux-gnu/tls/i686", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/lib/i486-linux-gnu/tls/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/lib/i486-linux-gnu/tls/sse2/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/lib/i486-linux-gnu/tls/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib/i486-linux-gnu/tls/sse2", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/lib/i486-linux-gnu/tls/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib/i486-linux-gnu/tls/cmov", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/lib/i486-linux-gnu/tls/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib/i486-linux-gnu/tls", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib/i486-linux-gnu/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1
stat64("/lib/i486-linux-gnu/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No
open("/lib/i486-linux-gnu/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib/i486-linux-gnu/i686/sse2", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/lib/i486-linux-gnu/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib/i486-linux-gnu/i686/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/lib/i486-linux-gnu/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib/i486-linux-gnu/i686", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib/i486-linux-gnu/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/lib/i486-linux-gnu/sse2/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/lib/i486-linux-gnu/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib/i486-linux-gnu/sse2", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib/i486-linux-gnu/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/lib/i486-linux-gnu/cmov", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/lib/i486-linux-gnu/libproj.so.0", O_RDONLY) = -1 ENOENT (No such file
or directory)
stat64("/lib/i486-linux-gnu", 0xffd57760) = -1 ENOENT (No such file or
directory)
open("/usr/lib/i486-linux-gnu/tls/i686/sse2/cmov/libproj.so.0", O_RDONLY) =
stat64("/usr/lib/i486-linux-gnu/tls/i686/sse2/cmov", 0xffd57760) = -1 ENOENT
open("/usr/lib/i486-linux-gnu/tls/i686/sse2/libproj.so.0", O_RDONLY) = -1
stat64("/usr/lib/i486-linux-gnu/tls/i686/sse2", 0xffd57760) = -1 ENOENT (No
open("/usr/lib/i486-linux-gnu/tls/i686/cmov/libproj.so.0", O_RDONLY) = -1
stat64("/usr/lib/i486-linux-gnu/tls/i686/cmov", 0xffd57760) = -1 ENOENT (No
open("/usr/lib/i486-linux-gnu/tls/i686/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/usr/lib/i486-linux-gnu/tls/i686", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib/i486-linux-gnu/tls/sse2/cmov/libproj.so.0", O_RDONLY) = -1
stat64("/usr/lib/i486-linux-gnu/tls/sse2/cmov", 0xffd57760) = -1 ENOENT (No
open("/usr/lib/i486-linux-gnu/tls/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/usr/lib/i486-linux-gnu/tls/sse2", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib/i486-linux-gnu/tls/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/usr/lib/i486-linux-gnu/tls/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib/i486-linux-gnu/tls/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/usr/lib/i486-linux-gnu/tls", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/usr/lib/i486-linux-gnu/i686/sse2/cmov/libproj.so.0", O_RDONLY) = -1
stat64("/usr/lib/i486-linux-gnu/i686/sse2/cmov", 0xffd57760) = -1 ENOENT (No
open("/usr/lib/i486-linux-gnu/i686/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/usr/lib/i486-linux-gnu/i686/sse2", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib/i486-linux-gnu/i686/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/usr/lib/i486-linux-gnu/i686/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib/i486-linux-gnu/i686/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/usr/lib/i486-linux-gnu/i686", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/usr/lib/i486-linux-gnu/sse2/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT
stat64("/usr/lib/i486-linux-gnu/sse2/cmov", 0xffd57760) = -1 ENOENT (No such
file or directory)
open("/usr/lib/i486-linux-gnu/sse2/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/usr/lib/i486-linux-gnu/sse2", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/usr/lib/i486-linux-gnu/cmov/libproj.so.0", O_RDONLY) = -1 ENOENT (No
stat64("/usr/lib/i486-linux-gnu/cmov", 0xffd57760) = -1 ENOENT (No such file
or directory)
open("/usr/lib/i486-linux-gnu/libproj.so.0", O_RDONLY) = -1 ENOENT (No such
file or directory)
stat64("/usr/lib/i486-linux-gnu", 0xffd57760) = -1 ENOENT (No such file or
directory)
writev(2, [{"g.region", 8}, {": ", 2}, {"error while loading shared
libra"..., 36}, {": ", 2}, {"libproj.so.0", 12}, {": ", 2}, {"cannot open
shared object file", 30}, {": ", 2}, {"No such file or directory", 25},
{"\n", 1}], 10g.region: error while loading shared libraries: libproj.so.0:
cannot open shared object file: No such file or directory
) = 120
exit_group(127) = ?
On Mon, Dec 14, 2009 at 4:02 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Isaac Ullah wrote:
> > I've been trying to compile and install GRASS 7 on Ubuntu 9.10. I am
> > using the same methodology that has been successful for me with previous
> > version of Ubuntu. I have been able to successfully make binaries with no
> > errors, but I consistently get gdal/proj errors when I launch the gui. I
> > have tried with the precompiled ubuntu binaries of GDAL/PROJ as well as
> > building them from latest source (no errors). i've even tried the old
> > "compile GDAL first without GRASS support, then compile GRASS, then redo
> > GDAL with GRASS support" trick, and this does not work either. Here are
> the
> > errors:
> > Welcome to GRASS 7.0.svn (2009)
> > GRASS homepage: http://grass.osgeo.org/
> > This version running through: Bash Shell (/bin/bash)
> > Help is available with the command: g.manual -i
> > See the licence terms with: g.version -c
> > If required, restart the GUI with: g.gui wxpython
> > When ready to quit enter: exit
> > To run a command as administrator (user "root"), use "sudo <command>".
> > See "man sudo_root" for details.
> > GRASS 7.0.svn (jordan_wgs84):~/grass_7_source/grass_trunk > g.gui
> wxpython
> > WARNING: Vector digitizer is not available (No module named
> > grass7_wxvdigit).
> > Note that vector digitizer is currently not working under MS Windows
> > (hopefully will be fixed soon). Please try more recent version of GRASS.
> > g.list: error while loading shared libraries: libgdal.so.1: cannot open
> > GRASS 7.0.svn (jordan_wgs84):~/grass_7_source/grass_trunk > whereis
> libgdal.so.1
> > libgdal.so: /usr/lib/libgdal.so.1 /usr/lib64/libgdal.so.1
> > /usr/local/lib/libgdal.so /usr/local/lib/libgdal.so.1
> > GRASS 7.0.svn (jordan_wgs84):~/grass_7_source/grass_trunk > g.region -p
> > g.region: error while loading shared libraries: libproj.so.0: cannot open
> libproj.so.0
> > libproj.so: /usr/lib/libproj.so.0 /usr/lib/libproj.so
> > /usr/lib64/libproj.so.0 /usr/lib64/libproj.so
> > Clearly you can see that I have both libgdal.so.1 and libproj.so.0
> installed
> > in standard locations, and they are in the PATH.
> This is kind of clutching at straws, but:
> 1. Is /usr/lib64 listed in /etc/ld.so.conf?
> 2. Has "ldconfig" been run since the libraries were installed?
> The loader doesn't scan the system directories looking for libraries;
> it uses /etc/ld.so.cache, which is generated by ldconfig. If
> ld.so.cache isn't up to date, libraries may not be found.
> If you have "strace" installed, try:
> strace g.region -p
> This will show all of the system calls which are being made, including
> the loading of shared libraries. It may provide some clues as to what
> is going wrong.
Isaac I Ullah, M.A.
Archaeology PhD Candidate,
ASU School of Evolution and Social Change
Research Assistant,
Mediterranean Landscape Dynamics Project
ullah at archaeologist.com
http://www.public.asu.edu/~iullah
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20091218/0b70e430/attachment-0001.html
