[GRASS-dev] Secret to compiling GRASS 7 on Ubuntu 9.10?
Isaac Ullah isaac.ullah at asu.edu
Fri Dec 18 16:50:38 EST 2009
Oh boy... That seems like a pretty big issue... My configure options for
grass have 64-bit enabled, so shouldn't that set it up to look for all
64-bit architecture? The contents of /etc/ld.so.conf.d/ are libc.conf and
x86_64-linux-gnu.conf. The firs contains "# libc default configuration
\n/usr/local/lib", and the second contains "# Multiarch support
\n/lib/x86_64-linux-gnu \n/usr/lib/x86_64-linux-gnu".  No /usr/lib64 in
either of them. Shall I try to add t hat as a line
in one of these files?
Cheers,
Isaac
> On Fri, Dec 18, 2009 at 2:21 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
>> Isaac Ullah wrote:
>> > Thanks for the ideas. My ld.config.so only has one line: "include
>> > /etc/ld.so.conf.d/*.conf" . What else should it have? Can I just add "
>> > /usr/lib64" as a line? What would be the syntax?
>> I assume that it behaves as if ld.so.conf contained the result of
>> "cat /etc/ld.so.conf.d/*.conf", so look at what's in those files.
>> > I ran ldconfig, and then
>> > tried again (make clean, make, make install), but it still does not
>> work.
>> > Output of strace g.region -p is:
>> > GRASS 7.0.svn (jordan_wgs84):~/grass_7_source/grass_trunk > strace
>> g.region -p
>> [snip]
>> Wow; 65 attempts and it still fails.
>> At a wild guess, I'd assume that it's a 32-bit/64-bit mismatch. The
>> output from strace suggests that it's looking for a 32-bit library,
>> but if proj is in /usr/lib64, I'd assume that it's a 64-bit library.
>> If it *requires* a 32-bit library and you only have a 64-bit library,
>> no amount of configuration will make it work. But I don't have a
>> 64-bit system, so I'm not too familiar with the issues involved.
> Isaac I Ullah, M.A.
> Archaeology PhD Candidate,
> ASU School of Evolution and Social Change
> Research Assistant,
> Mediterranean Landscape Dynamics Project
> ullah at archaeologist.com
> http://www.public.asu.edu/~iullah <http://www.public.asu.edu/%7Eiullah>
Isaac I Ullah, M.A.
Research Assistant,
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20091218/91208f49/attachment.html
