[GRASS-dev] Re: [GRASS GIS] #841: python script modules should use
pythonw on OSX; they also ignore GRASS_PYTHON
trac at osgeo.org
Mon Dec 21 00:05:57 EST 2009
#841: python script modules should use pythonw on OSX; they also ignore
GRASS_PYTHON
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by glynn):
Replying to [ticket:841 kyngchaos]:
> wxpython-based python scripts on OSX should be run with pythonw.
Problem in 6.5 in the new v.krige, and of course in all 7.x scripts.
Most 7.x scripts don't use wxPython directly. They might use it indirectly
via g.parser, but that should be dealt with by $GRASS_PYTHON.
> This is fine for the GUI itself, since the gui script is executed from
Python (GRASS_PYTHON). But modules are executed directly, using the
#!/usr/bin/env/python
> method.
That should be:
#!/usr/bin/env python
No slash between "env" and "python".
> For OSX, this should be
#!/usr/bin/env/pythonw
> This will probably need to use some kind of .in file for all script
modules that gets processed during make :(
AFAICT, most scripts should be using "python", not "pythonw"
> Though, I see another potential problem with the #! -- it completely
ignores GRASS_PYTHON,
That shouldn't be a problem.
> which could cause trouble if the user or packager wants to override the
default python in the PATH. I don't know if it's possible to make the #!
more dynamic.
It isn't. The kernel doesn't understand environment variables.
Ticket URL: <https://trac.osgeo.org/grass/ticket/841#comment:1>
