[GRASS-dev] Re: [GRASS GIS] #841: python script modules should use
pythonw on OSX; they also ignore GRASS_PYTHON
trac at osgeo.org
Mon Dec 21 10:15:31 EST 2009
#841: python script modules should use pythonw on OSX; they also ignore
GRASS_PYTHON
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by kyngchaos):
Replying to [comment:1 glynn]:
> Most 7.x scripts don't use wxPython directly. They might use it
indirectly via g.parser, but that should be dealt with by $GRASS_PYTHON.
OK. I was going by the new v.krige in 6.5, where I noticed the problem.
So, the g.parser stuff happens in a completely separate process? What I
saw in one module I looked at is that the script loads the grass module,
then runs grass.parser(), then runs the main script. No chance for it to
run anything with GRASS_PYTHON.
> No slash between "env" and "python".
fingers acted on their own ;)
> AFAICT, most scripts should be using "python", not "pythonw"
Except when they use wx, like v.krige.
>> Though, I see another potential problem with the #! -- it completely
ignores GRASS_PYTHON,
> That shouldn't be a problem.
How is that not a problem? Say there are 2 pythons in the PATH (or
another not in the PATH) and I don't want to use the first one, so I set
GRASS_PYTHON to the full path to the other. But then /usr/bin/env
python[w] goes and runs the first one anyways.
Ticket URL: <https://trac.osgeo.org/grass/ticket/841#comment:2>
