[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass
	release
    trac at osgeo.org
    Fri Dec 25 07:30:55 EST 2009
#843: v.digit broken on new WinGrass release
  Reporter:  cnielsen      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Vector        |     Version:  unspecified
Resolution:                |    Keywords:  wingrass,v.digit
  Platform:  MSWindows XP  |         Cpu:  x86-64
Comment (by marisn):
 Replying to [comment:12 glynn]:
 > Replying to [comment:11 marisn]:
 > > As lib/forms F_open is used only by v.digit and d.what.vect,
 > It's used by d.what.vect and NVIZ.
 d.what.vect AFAIK doesn't work on Windows due to X dependency. Not a
 issue.
 NVIZ does '''NOT''' use F_open(). lib/forms are used by more than v.digit
 and d.what.vect modules, but only those two call F_open(). Others use
 plain F_generate, which works just fine.
 > v.digit doesn't use lib/form (at least, it's not '''supposed''' to use
 lib/form, as it has its own version of the code).
 Only part of the form lib that '''could''' be v.digit own, is F_open() and
 also only because it's not worth effort to make lib/form F_open() Windows-
 ready. F_generate() is generic enough to NOT keep many copies around.
Ticket URL: <https://trac.osgeo.org/grass/ticket/843#comment:13>
