[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass
release
trac at osgeo.org
Sat Dec 26 07:18:21 EST 2009
#843: v.digit broken on new WinGrass release
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords: wingrass,v.digit
Platform: MSWindows XP | Cpu: x86-64
Comment (by glynn):
Replying to [comment:13 marisn]:
> > > As lib/forms F_open is used only by v.digit and d.what.vect,
> > It's used by d.what.vect and NVIZ.
> d.what.vect AFAIK doesn't work on Windows due to X dependency. Not a
issue.
> NVIZ does '''NOT''' use F_open(). lib/forms are used by more than
v.digit and d.what.vect modules, but only those two call F_open(). Others
use plain F_generate, which works just fine.
v.digit doesn't use lib/form's F_{open,clear,close} functions; it has its
own functions with those names, which don't spawn a separate process.
Except, linking against lib/form for F_generate() seems to cause
lib/form's F_open (etc) to override the local version.
It would be possible to modify v.digit to use different names (this may
also need to be done for reset_values(), set_value() and submit() in
form.c), but I'm still concerned about the potential side-effects of
linking against lib/form. Personally, I consider cloning F_generate() to
be the lesser evil.
If d.what.vect is the only module which uses lib/form's F_open(), I'd
consider removing that code from lib/form and putting it in d.what.vect
instead. That would simplify lib/form and eliminate the Windows issues.
Ticket URL: <https://trac.osgeo.org/grass/ticket/843#comment:14>
