[GRASS-dev] Re: [GRASS GIS] #660: v.delaunay producing incorrect
results
trac at osgeo.org
Thu Dec 31 05:06:21 EST 2009
#660: v.delaunay producing incorrect results
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords: delaunay
Platform: MacOSX | Cpu: OSX/Intel
Comment (by mmetz):
Replying to [comment:12 marisn]:
> MarkusM - what's up with those warnings in vlib/diglib code?
I assume you refer to the valgrind output, at least I don't get any
warnings when running v.delaunay without valgrind. The only valgrind
errors that tell me something are right at the beginning, here
http://trac.osgeo.org/grass/attachment/ticket/660/delaunay-
valgrind1.txt#L17
and here
valgrind1.txt#L27
The second one saying that Address 0x66d5f29 is 9 bytes inside a block of
size 4,096 alloc'd may cause problems, but I have not the faintest idea
where this is coming from, I don't get this one on Linux, only number 1.
If all other vector modules are working, the problem is IMHO more likely
somewhere in the module than in the vector libs. So, are other vector
modules working?
On my Linux system, v.delaunay is fast and produces correct results, also
with e.g. elev_lid792_bepts with 118,716 points.
Sorry, not much help from my side,
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/660#comment:15>
