[GRASS-dev] [GRASS GIS] #474: r.quantile: segfaults with
	percentile=100
    trac at osgeo.org
    Tue Feb  3 18:04:55 EST 2009
#474: r.quantile: segfaults with percentile=100
 Reporter:  hamish      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  6.4.0
Component:  Raster      |     Version:  svn-develbranch6
 Keywords:  r.quantile  |    Platform:  Linux
      Cpu:  x86-32      |
 spearfish:
 g.region rast=elevation.10m
 r.quantile elevation.10m percentile=0,10,20,30,40,50,60,70,80,90,100
 Computing histogram
  100%
 Computing bins
 Binning data
  100%
 Sorting bins
  100%
 Computing quantiles
 0:0.000000:1061.064087
 1:10.000000:1159.293774
 2:20.000000:1184.320190
 3:30.000000:1210.821362
 4:40.000000:1251.937646
 5:50.000000:1309.368164
 6:60.000000:1378.708764
 7:70.000000:1440.232398
 8:80.000000:1525.849707
 9:90.000000:1613.602832
 Segmentation fault
 gdb:
 Program received signal SIGSEGV, Segmentation fault.
 0x08049205 in compute_quantiles (recode=0) at main.c:209
 209             v = (i0 == i1)
 (gdb) bt
 #0  0x08049205 in compute_quantiles (recode=0) at main.c:209
 #1  0x0804975c in main (argc=0, argv=0x3ff00000) at main.c:326
 (gdb) list
 204
 205             k = next - b->origin;
 206             i0 = (int)floor(k);
 207             i1 = (int)ceil(k);
 208
 209             v = (i0 == i1)
 210                 ? values[b->base + i0]
 211                 : values[b->base + i0] * (i1 - k) + values[b->base +
 i1] * (k -
 212
 i0);
 213
   (gdb) bt full
         k = 2654489
         i1 = 2654489
         next = 2654802
         v = 1613.6028318000001
         i0 = 2654489
         b = (struct bin *) 0x805e9e4
         prev_v = 1613.6028318000001
         quant = 10
         module = (struct GModule *) 0xb7f3f170
         opt = {input = 0xb7f3f120, quant = 0x804b028, perc = 0x804b088,
   slots = 0x804b0e8}
         flag = {r = 0xb7f3f0fc}
         recode = 0
         infile = 6
         range = {min = 1061.064087, max = 1846.743408, first_time = 0}
 presumably values[b->base + i0] is just outside the array.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/474>
