[GRASS-dev] Re: [GRASS GIS] #474: r.quantile: segfaults with
percentile=100
trac at osgeo.org
Tue Feb 10 11:15:29 EST 2009
#474: r.quantile: segfaults with percentile=100
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: r.quantile
Platform: Linux | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:474 hamish]:
> presumably values[b->base + i0] is just outside the array.
Actually, it's way outside the array, as the last bin never gets
initialised.
Hopefully fixed in r35846.
This also fixes a bug where the quantile corresponds to the last value in
the bin (e.g. if there is only one value in the bin). The interpolation
will use the first value from the bin for the next quantile, which could
be way off.
Ideally, it should retain the values from the following bin in case one is
needed for interpolation. In practice, this won't make much difference.
Ticket URL: <https://trac.osgeo.org/grass/ticket/474#comment:1>
