[GRASS-dev] [GRASS GIS] #483: "return to previous zoom" brakes
"zoom to selected map"
trac at osgeo.org
Sat Feb 7 16:25:45 EST 2009
#483: "return to previous zoom" brakes "zoom to selected map"
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
1. on the terminal set the region to a subset of the raster map you will
load in step 3
2. start wxGUI
3. add a raster map
4. "zoom to selected map"
5. query the map several times
6. "return to previous zoom" - the view changes to the region from step 1
7. query the map several times again
8. try "zoom to selected map" - the view fails to change
FWIW, while I was fiddling with querying and zooming the whole gui crashed
once, leaving a trace in dmesg:
[30891.603698] python[22007]: segfault at 2d56470 ip 2d56470 sp
7fff3623cb58 error 15
Ticket URL: <http://trac.osgeo.org/grass/ticket/483>
