[GRASS-dev] vector large file support
Thu Feb 12 06:12:30 EST 2009
Markus Metz wrote:
> The dglib is still a mystery to me. I don't even know what modules use
> it. The other vector libs don't use it, that I'm relatively sure of.
The vector library (libgrass_vect, aka lib/vector/Vlib) uses it
(graph.c, net.c), as does v.generalize.
If you want to track symbol definitons and references, look at
tools/sql.sh.
