[GRASS-dev] my custom ps.map to ps3.map
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Feb 16 02:56:53 EST 2009
this looks great! Is there support for i18n as well?
Jachym
E. Jorge Tizado píše v Ne 15. 02. 2009 v 15:07 +0100:
> Hi Hamish,
> I make many changes to the files in ps.map and to avoid conflict with this
> standard command I move my custom ps.map to ps3.map.
> This ps3.map compile whithout errors in grass6_devel (6.5.svn). Before I send
> this addons (or substitute of ps.map) I want debug and improve some part of
> code but I like know the opinion and suggestions to improve the command
> needed to draw quality maps whitout any other extern software.
> The main improvements are:
> 1. All font has color.
> 2. All colors are R:G:B (accept named and none, of course).
> 3. Many dimensions accept unit (milimeters, centimeters and inches, default
> points).
> - Grid: option of fcolor to look like as ps3_map_grid.jpg (with a border of 2
> points)
> - Areas: it is possible define style of line to look as 'Geology-262' in
> - Lines: it is possible define style to hline to look as 'Railroads' in
> - Scalebar: now with fcolor to look as ps3_map_scalebar.jpg
> - rlegend and vlegend: with frame and multicolumns work well as
> ... and more.
> Also I send to Grass-Addons server (GRASS7 subdir) i.landsat.toar and
> i.topo.corr; They compile without errors in GRASS7 but I can not test because
> teh compilation of GRASS_7 give me errors in many files, mainly because:
> /usr/local/grass-6.4.0svn/lib/libgrass_I.so: undefined reference to `G_gets'
> `G_get_ask_return_msg'
> collect2: ld returned 1 exit status
> Thank for suggestions and comments
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
