[GRASS-dev] oproj void** invalid conversion
Andreas Jochem andruit at gmx.de
Mon Feb 16 12:21:33 EST 2009
I am trying to convert Coordinates to lat / long. I would like to save
the output projection parameters in oproj.
But the compiler is complaining.
error: invalid conversion from ‘void*’ to ‘void**’.
If I use *oproj.pj instead of oproj.pj the compiler doesn't complain
anymore but the transformation to lat / long does not work.
The code is following below.
Does anybody know this problem. I used this code a couple of months ago
and it worked.
Thanks
Andi
struct Key_Value *in_proj_info, *in_unit_info; /* projection information
of input map */
struct pj_info iproj; /* input map proj parameters */
struct pj_info oproj; /* output map proj parameters */
/* read current projection info */
if ((in_proj_info = G_get_projinfo()) == NULL)
G_fatal_error("Can't get projection info of current location");
if ((in_unit_info = G_get_projunits()) == NULL)
G_fatal_error("Can't get projection units of current location");
if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
G_fatal_error("Can't get projection key values of current location");
G_free_key_value( in_proj_info );
G_free_key_value( in_unit_info );
oproj.zone = 0;
oproj.meters = 1.;
sprintf(oproj.proj, "ll");
if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
G_fatal_error("Unable to set up lat/long projection parameters");
