[GRASS-dev] Re: [GRASS GIS] #502: wxgui / osgeo4w: db.describe
execution failed
trac at osgeo.org
Mon Feb 23 23:46:59 EST 2009
#502: wxgui / osgeo4w: db.describe execution failed
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.0
Component: Database | Version: 6.4.0 RCs
Resolution: | Keywords: osgeo4w
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
Replying to [comment:4 martinl]:
> Copying files from relbr64 should work.
ok, I tried again with full dir, seemed to start up ok this time.
adding vector maps works without error, as does querying vector and raster
maps.
I notice trying to Query vector map (edit mode) for roads at PERMANENT
[spearfish] gives me a pop up window error about not being able to find
the DBF file, and if I try again I get a traceback error in the Command
Output window. It should error-out if the map in not in the current mapset
(perhaps at the module level?) as @othermapset should always be read-only.
strangely the rendered map in the map display canvas became smaller while
I was doing these tests (first just a sliver on the right, then when I hit
the eyeball redraw button about 1/2 the canvas width). [Render [] is
ticked] Zoom to selected map didn't help, needed to fully use the zoom
_(+) tool.
aaaaaaaaah, the surviving part of the map display is that which IS
overlapped by the Layer Manager window when I change the "Comand output"
tab to "map layers for display" then put the Map display window back on
top. very weird. "Re-render map" doesn't help, but the pan tool does.
Again: clicking the eyeball makes the unoverlapped part disappear. now it
works. strange, maybe change of map (roads(vect)/elevation.10m) is part of
it. ??
hmmph, oh well. something to keep an eye out for.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/502#comment:5>
