[GRASS-dev] Re: [GRASS GIS] #502: wxgui / osgeo4w: db.describe execution failed
GRASS GIS trac at osgeo.org
Wed Feb 25 06:15:41 EST 2009
  Reporter:  hamish        |       Owner:  martinl
      Type:  defect        |      Status:  assigned
  Priority:  major         |   Milestone:  6.4.0
 Component:  Database      |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  osgeo4w
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by martinl):
 Replying to [comment:5 hamish]:
 > I notice trying to Query vector map (edit mode) for roads at PERMANENT
 [spearfish] gives me a pop up window error about not being able to find
 the DBF file, and if I try again I get a traceback error in the Command
 Output window. It should error-out if the map in not in the current mapset
 (perhaps at the module level?) as @othermapset should always be read-only.
 in r36092 is added check for vector map mapset, in the result it's
 possible to query in this mode only vector maps from the current mapset.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/502#comment:6>
