[GRASS-dev] cleaning large vector files
Markus Metz
markus.metz.giswork at googlemail.com
Tue Feb 24 03:42:09 EST 2009
Wouter Boasson wrote:
> #494
> I checked my swapfile, and under Mac OS there was certainly enough memory
> available (4GB RAM and virtually unlimited swap, 64bit address space). This
> did not help the clean action to complete successfully. Then, as you
> suggested, I decided to recompile the 6.5dev branch (I used OpenSuse 11
> Linux 64bit), and gave it a vast 3GB RAM + a 9GB swap partition. When
> looking at the output v.clean only tried to allocate a mere 34MB, and the
> system had about 9GB available at that time. So, I don't think my RAM
> availability is the problem...
Strange. I have recently cleaned a 0.8GB vector, successfully, also
using break polygons amongst other cleaning tools. Both RAM and swap
were used, no problems. No idea why the reallocation fails. The only
idea I have is that swap space is not used, but that doesn't make sense.
Looking at the topology, this is a lot of vertices, boundaries and
centroids, but nothing that grass can't handle.
Memory reallocation in break_polygons.c line 188 didn't give me problems
before. There were other problems further down when breaking polygons,
but these should be solved in 6.5 and 7.
A common pitfall with a new grass installation is that libraries of an
older grass version are used (a wild guess):
Is gdal compiled with grass support using an older grass version? If
yes, remove grass support from gdal.
Is the path to old grass libraries somewhere in the system path for
libraries? If yes, remove that path and run ldconfig on Linux.
As a last resort I can offer you to give it a try myself. I can give you
an ftp address where you can upload that beast and then I will see if I
can reproduce the error. Or you give me a link where to download that
vector. If the data are sensitive, you could remove the attribute table
first. I would use grass65 on Linux Fedora 10 64bit.
Regards,
Markus M
> GRASS 6.5.svn (nl-rdn):~ > v.clean in=top_top10vec_gebouwen
> out=top_top10vec_gebclean tool=bpol
> Tool: Threshold
> Break polygons: 0.000000e+00
> Copying vector lines...
> Rebuilding parts of topology...
> Building topology for vector map <top_top10vec_gebclean>...
> Registering primitives...
> 6041168 primitives registered
> 25000849 vertices registered
> Number of nodes: 6037532
> Number of primitives: 6041168
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 3021055
> Number of centroids: 3020113
> Number of areas: -
> Number of isles: -
> Tool: Break polygons
> ERROR: G_realloc: unable to allocate 34800040 bytes at break_polygons.c:188
