[GRASS-dev] missing programmer's manual?
Markus Neteler
neteler at osgeo.org
Thu Jan 1 12:27:47 EST 2009
On Thu, Jan 1, 2009 at 6:16 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Jan 1, 2009 at 12:16 AM, Michael Barton <michael.barton at asu.edu> wrote:
>> I wanted to look in the programer's manual in case call from TclTk to C for
>> NVIZ are listed somewhere. I'm not optimistic, but it's worth checking. I
>> went to the on-line development page to find it
>> <http://grass.osgeo.org/devel/index.php#prog>. The link to the on-line html
>> works fine. But went I went to try to download something, I ran into
>> trouble. The on-line PDF for download link goes to a blank page
>> <http://download.osgeo.org/grass/grass6_progman_pdf/>.
> The PDF cronjob is actually broken. I'll look into this.
I guess I found it. The directory should be now populated with PDFs over
the next hour.
However, NVIZ isn't documented with doxygen, basically the GRASS libs
are.
Markus
