[GRASS-dev] missing programmer's manual?
Michael Barton
michael.barton at asu.edu
Thu Jan 1 12:47:53 EST 2009
On Jan 1, 2009, at 10:27 AM, Markus Neteler wrote:
> On Thu, Jan 1, 2009 at 6:16 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
>> On Thu, Jan 1, 2009 at 12:16 AM, Michael Barton <michael.barton at asu.edu
>> > wrote:
>>> I wanted to look in the programer's manual in case call from TclTk
>>> to C for
>>> NVIZ are listed somewhere. I'm not optimistic, but it's worth
>>> checking. I
>>> went to the on-line development page to find it
>>> <http://grass.osgeo.org/devel/index.php#prog>. The link to the on-
>>> line html
>>> works fine. But went I went to try to download something, I ran into
>>> trouble. The on-line PDF for download link goes to a blank page
>>> <http://download.osgeo.org/grass/grass6_progman_pdf/>.
>> The PDF cronjob is actually broken. I'll look into this.
> I guess I found it. The directory should be now populated with PDFs
> over
> the next hour.
> However, NVIZ isn't documented with doxygen, basically the GRASS libs
> are.
Thanks. I found a fix for loading 3D points to nviz from the command
line without first loading a surface. Just committed to 35144 db6,
35145 rb, and 35146 trunk.
