[GRASS-dev] 64 bit compiling of GRASS 7 on Mac
Michael Barton
michael.barton at asu.edu
Tue Jan 6 01:02:38 EST 2009
I tried compiling GRASS 7 with 64bit enabled on my Mac. I configured
without tcltk. It actually went pretty well. It hung at g.mapsets, but
this compiled when I cd'ed to the folder and ran make. The only thing
that didn't compile was gidlib.
I've put my configuration and error output below in case it is
informative.
Michael
export CFLAGS="-arch i386 -arch x86_64 -Os"
export CXXFLAGS="-arch i386 -arch x86_64 -Os"
export LDFLAGS="-arch i386 -arch i386 -Os"
./configure --with-freetype --with-freetype-includes="/Library/
Frameworks/FreeType.framework/unix/include/freetype2 /Library/
Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/
Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/
Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-
includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-
libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/
Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-includes=/
Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-
libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-
includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-
png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-
tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --
without-postgres --without-mysql --with-odbc --with-sqlite --with-
sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-
sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --
with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --
with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --
with-cxx --with-opengl=aqua --without-readline --prefix=/Applications/
GRASS --enable-macosx-app --with-python=/usr/bin/python-config --with-
wxwidgets=/usr/local/lib/wxPython-unicode-2.8.9.1/bin/wx-config --
without-tcltk
compiling
Started compilation: Mon Jan 5 22:47:43 MST 2009
Errors in:
/Users/cmbarton/grass_dev/grass7_src/lib/vector/diglib
/Users/cmbarton/grass_dev/grass7_src/general/g.mapsets
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you
will
also get errors from anything which uses the library.
Finished compilation: Mon Jan 5 22:55:21 MST 2009
make: *** [default] Error 1
cmb-MBP-2:grass7_src cmbarton$ cd /Users/cmbarton/grass_dev/grass7_src/
lib/vector/diglib
cmb-MBP-2:diglib cmbarton$ make
if [ "" != "" -a -f "".html ] ; then make html ; fi
make OBJ.i386-apple-darwin9.6.0/test
echo "==============TEST============="
gcc -L/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/
lib -arch i386 -arch i386 -Os -arch i386 -arch i386 -Os -arch i386
-arch x86_64 -Os -I/Library/Frameworks/GDAL.framework/Versions/1.6/
Headers -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/test test.c -
lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -
lgrass_rtree \
-lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lz
ld warning: in /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
darwin9.6.0/lib/libgrass_dig2.dylib, file is not of required
architecture
darwin9.6.0/lib/libgrass_gis.dylib, file is not of required architecture
darwin9.6.0/lib/libgrass_datetime.dylib, file is not of required
architecture
darwin9.6.0/lib/libgrass_rtree.dylib, file is not of required
architecture
Undefined symbols for architecture x86_64:
"_dig_fflush", referenced from:
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
"_dig_set_cur_port", referenced from:
_main in ccBWlQqE.o
"_dig__fread_port_C", referenced from:
_main in ccBWlQqE.o
"_dig__fread_port_D", referenced from:
_main in ccBWlQqE.o
"_dig__fread_port_F", referenced from:
_main in ccBWlQqE.o
"_dig__fread_port_I", referenced from:
_main in ccBWlQqE.o
"_dig__fread_port_L", referenced from:
_main in ccBWlQqE.o
"_dig__fread_port_S", referenced from:
_main in ccBWlQqE.o
"_dig_fseek", referenced from:
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
_main in ccBWlQqE.o
"_dig__fwrite_port_C", referenced from:
_main in ccBWlQqE.o
"_dig__fwrite_port_D", referenced from:
_main in ccBWlQqE.o
"_dig__fwrite_port_F", referenced from:
_main in ccBWlQqE.o
"_dig__fwrite_port_I", referenced from:
_main in ccBWlQqE.o
"_dig__fwrite_port_L", referenced from:
_main in ccBWlQqE.o
"_dig__fwrite_port_S", referenced from:
_main in ccBWlQqE.o
"_dig_init_portable", referenced from:
_main in ccBWlQqE.o
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
lipo: can't open input file: /var/folders/AK/AKpYwDw1EoWI+fFF02nvRk++
+TI/-Tmp-//ccUxiMSI.out (No such file or directory)
make[1]: *** [OBJ.i386-apple-darwin9.6.0/test] Error 1
make: *** [default] Error 2
cd /Users/cmbarton/grass_dev/grass7_src/general/g.mapsets
cmb-MBP-2:g.mapsets cmbarton$ make
if [ ! -d /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
darwin9.6.0/etc ]; then mkdir -p /Users/cmbarton/grass_dev/grass7_src/
dist.i386-apple-darwin9.6.0/etc; fi
/usr/bin/install -c g.mapsets.py /Users/cmbarton/grass_dev/grass7_src/
dist.i386-apple-darwin9.6.0/etc/gui/g.mapsets.py
