[GRASS-dev] Re: [GRASS GIS] #424: AC_CONFIG_AUX_DIR added in
configure.in of 6.4.x causes rpmbuild failure
trac at osgeo.org
Tue Jan 6 19:38:37 EST 2009
#424: AC_CONFIG_AUX_DIR added in configure.in of 6.4.x causes rpmbuild failure
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: Linux | Cpu: All
Comment (by glynn):
Replying to [ticket:424 neteler]:
> The following addition to configure.in of 6.4.x:
> +AC_CONFIG_AUX_DIR($SRCDIR)
> leads to this error when creating a (Mandriva) RPM from 6.4.0RC1:
> + cputoolize -c .
> libtoolize: cannot handle variables in AC_CONFIG_AUX_DIR
This looks like a problem with the RPM spec file. GRASS doesn't use
libtool. The build process shouldn't be concerning itself with the
contents of those scripts, just running configure.
> Do we really need AC_CONFIG_AUX_DIR (e.g., in GRASS 6.3 it wasn't
needed) or can it be conditionalized?
It's needed, and I don't think that it can be conditionalised.
Ticket URL: <http://trac.osgeo.org/grass/ticket/424#comment:2>
