[GRASS-dev] Re: [GRASS GIS] #424: AC_CONFIG_AUX_DIR added in
configure.in of 6.4.x causes rpmbuild failure
trac at osgeo.org
Wed Jan 7 03:42:31 EST 2009
#424: AC_CONFIG_AUX_DIR added in configure.in of 6.4.x causes rpmbuild failure
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: wontfix | Keywords:
Platform: Linux | Cpu: All
Changes (by neteler):
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [comment:2 glynn]:
> Replying to [ticket:424 neteler]:
> > libtoolize: cannot handle variables in AC_CONFIG_AUX_DIR
> It's needed, and I don't think that it can be conditionalised.
OK, changing in the SPEC file
%configure
to
./configure
works around the problem since libtool(ize) is then not used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/424#comment:3>
