[GRASS-dev] Re: [GRASS GIS] #398: r.watershed with MFD
trac at osgeo.org
Wed Jan 7 06:33:24 EST 2009
Reporter: mmetz | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: reopened
Priority: minor | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by mmetz):
A new patch against trunk r35238 is attached, named
r.watershed.20090107.patch
This patch includes the following changes:
- MFD flow accumulation is slightly improved.
- MFD streams and basins are now equal to or better than SFD streams and
basins (they look more natural, no slivers or rectangles). Striking
differences are visible with elev_lid792_1m (multiplied by 1000 to get mm
accuracy) in nc_spm_08.
- Segmented mode is slightly faster, more noticeable with larger regions.
- In segmented mode, the dseg routines for DCELL output maps were actually
writing out CELL maps, not DCELL maps, changed to DCELL maps. DCELL_TYPE
is required for LS and S factor for USLE and for flow accumulation.
- Improved color rules for flow accumulation based on standard deviation
and log transformation, visual output would be obsolete now. BTW, in
visual output all cells with negative flow accumulation (offmap inflow)
are set to zero. That's an old, existing feature.
- In segmented mode, G_percent() in length slope determination is now
counting up, no longer counting down (was a FIXME).
Can you developers please test this patch? Thanks!
Happy New Year,
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/398#comment:6>
