[GRASS-dev] Re: [GRASS GIS] #111: r.los fails in WinGRASS with high
values for max_dis parameter
trac at osgeo.org
Fri Jan 9 07:15:13 EST 2009
#111: r.los fails in WinGRASS with high values for max_dis parameter
Reporter: gsancho | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: 6.3.0
Resolution: | Keywords: wingrass r.los
Platform: MSWindows XP | Cpu: x86-32
Changes (by aborruso):
* platform: => MSWindows XP
* component: default => Raster
* cpu: => x86-32
Comment:
I tested it on winxp sp3, and it crashes.
This is my command:
r.los input=DEM at andrea output=tr_vis coordinate=300877,4213602
obs_elev=1.75 max_dist=5000
I use GRASS 6.3.0 (2008) downloaded from:
http://grass.osgeo.org/grass63/binary/mswindows/native/WinGRASS-6.3.0-4-Setup.exe
Andrea
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:6>
