[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Markus Neteler neteler at osgeo.org
Fri Jan 9 10:44:53 EST 2009
On Fri, Jan 9, 2009 at 4:04 PM, Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi,
> I have now changed the OpenSuSE build server from GRASS 6.3 to 6.4 RC1. As for
> the version 6.3 I commented gui/wxpython/vdigit in gui/wxpython/Makefile to make
> it build.
(I assume due to the libgdi.so issue?)
Shouldn't --without.wxpython work?
> Packages are available for OpenSuSE 10.3, SLE_10, 11.0 and 11.1 i586 and x86_64.
> Can you please add this change to http://grass.osgeo.org/download/index.php and
> move the OpenSUSE Geo Repository link from 6.3 to 6.4?
Done:
http://grass.osgeo.org/download/index.php#g64x
Markus
> thanks a lot
>  Otto
> On Thu, 8 Jan 2009 15:36:22 +0100
>> On Thu, 8 Jan 2009 15:20:55 +0100
>> "Martin Landa" <landa.martin at gmail.com> wrote:
>> > Hi,
>> > 2009/1/7 Glynn Clements <glynn at gclements.plus.com>:
>> > > Martin Landa wrote:
>> > >> > make[3]: Entering directory
>> > >> > `/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython' python
>> > >> > gui_modules/menudata.py
>> > >> > /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu >
>> > >> > menustrings.py
>> > >> > Traceback (most recent call last): File "gui_modules/menudata.py", line
>> > >> > 24, in
>> > >> > <module> import elementtree.ElementTree as etree # Python <= 2.4
>> > >> > ImportError: No module named elementtree.ElementTree
>> > >> in Debian it's python-elementtree.
>> > > What? As in, they renamed the module so it doesn't work?
>> > > elementtree.ElementTree (xml.etree.ElementTree in >= 2.5) is part of
>> > > the core Python library, which is expected to be installed alongside
>> > > Python.
>> > hm, it seems to me that if you are using python <= 2.4 you need to
>> > install python-elementtree package - at least on Debian.
>> the problem above occurs with opensuse 11.0 (python 2.5.2). Maybe this
>> information is helpful:
>> http://lists.opensuse.org/opensuse-factory/2007-02/msg00177.html
>>  Otto
>> > Martin
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
