[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Otto Dassau otto.dassau at gmx.de
Fri Jan 9 10:50:10 EST 2009
On Fri, 9 Jan 2009 16:44:53 +0100
"Markus Neteler" <neteler at osgeo.org> wrote:
> On Fri, Jan 9, 2009 at 4:04 PM, Otto Dassau <otto.dassau at gmx.de> wrote:
> > Hi,
> > I have now changed the OpenSuSE build server from GRASS 6.3 to 6.4 RC1. As
> > for
> > the version 6.3 I commented gui/wxpython/vdigit in gui/wxpython/Makefile to
> > make it build.
> (I assume due to the libgdi.so issue?)
yes
> Shouldn't --without.wxpython work?
would that mean wxpython gui won't be build at all? Is that a configure option?
At the moment everything should work, except wxpython gui vdigit.
> > Packages are available for OpenSuSE 10.3, SLE_10, 11.0 and 11.1 i586 and
> > x86_64.
> > Can you please add this change to http://grass.osgeo.org/download/index.php
> > and move the OpenSUSE Geo Repository link from 6.3 to 6.4?
> Done:
> http://grass.osgeo.org/download/index.php#g64x
thanks!
 Otto
> Markus
> > thanks a lot
> >  Otto
> > On Thu, 8 Jan 2009 15:36:22 +0100
> >> On Thu, 8 Jan 2009 15:20:55 +0100
> >> "Martin Landa" <landa.martin at gmail.com> wrote:
> >> > Hi,
> >> > 2009/1/7 Glynn Clements <glynn at gclements.plus.com>:
> >> > > Martin Landa wrote:
> >> > >> > make[3]: Entering directory
> >> > >> > `/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython' python
> >> > >> > gui_modules/menudata.py
> >> > >> > /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu >
> >> > >> > menustrings.py
> >> > >> > Traceback (most recent call last): File "gui_modules/menudata.py",
line
> >> > >> > 24, in
> >> > >> > <module> import elementtree.ElementTree as etree # Python <= 2.4
> >> > >> > ImportError: No module named elementtree.ElementTree
> >> > >> in Debian it's python-elementtree.
> >> > > What? As in, they renamed the module so it doesn't work?
> >> > > elementtree.ElementTree (xml.etree.ElementTree in >= 2.5) is part of
> >> > > the core Python library, which is expected to be installed alongside
> >> > > Python.
> >> > hm, it seems to me that if you are using python <= 2.4 you need to
> >> > install python-elementtree package - at least on Debian.
> >> the problem above occurs with opensuse 11.0 (python 2.5.2). Maybe this
> >> information is helpful:
> >> http://lists.opensuse.org/opensuse-factory/2007-02/msg00177.html
> >>  Otto
> >> > Martin
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
