[GRASS-dev] Re: [GRASS GIS] #205: warnings and errors when trying
to print the display
trac at osgeo.org
Sat Jan 10 05:23:47 EST 2009
#205: warnings and errors when trying to print the display
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by msieczka):
* status: closed => reopened
* resolution: worksforme =>
Comment:
In opposite to Mac, print preview works on Debian testing. But WARNINGS
still crop out when I press the "Print" button in the print-preview
dialog:
(shoofi:8312): GnomePrint-WARNING **: Could not create filter from
description 'GnomePrintFilterSelect': filter 'GnomePrintFilterSelect' is
unknown
(shoofi:8312): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(shoofi:8312): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion
`G_TYPE_CHECK_INSTANCE (instance)' failed
description 'GnomePrintFilterClip [ GnomePrintFilterMultipage ]': filter
'GnomePrintFilterClip' is unknown
(shoofi:8312): GLib-GObject-CRITICAL **: g_object_unref: assertion
`G_IS_OBJECT (object)' failed
(shoofi:8312): libgnomeprintui-CRITICAL **:
gnome_print_layout_selector_load_filter: assertion `GNOME_IS_PRINT_FILTER
(f)' failed
(shoofi:8312): GLib-GObject-CRITICAL **: g_object_set: assertion
gnome_paper_selector_load_paper_size: assertion `GNOME_IS_PAPER_SELECTOR
(ps)' failed
(shoofi:8312): GnomePrint-CRITICAL **: gnome_print_filter_reset: assertion
`GNOME_IS_PRINT_FILTER (f)' failed
(shoofi:8312): GnomePrint-CRITICAL **: gnome_print_filter_flush: assertion
Then, switching between the PDF and PS output options yields another set
of warnings:
(ps)' failed
(ps)' failed
** (shoofi:8312): WARNING **: could not set the value of
Settings.Document.Filter, node not found
Finally, when printing to PS the following pops up:
description 'frgba': filter 'frgba' is unknown
And the output PS takes forever to render in Evince (never completes).
Interestingly, there are 2 pages instead of 1.
The PDF output renders fine. However, also 2 pages instead of 1 (both with
the same content).
Also, scale&arrow overlay brings a solid black polygon covering all the
map content below the scale&arrow, in the ouput PDF.
Ticket URL: <http://trac.osgeo.org/grass/ticket/205#comment:4>
