[GRASS-dev] gmath and gpde update
Glynn Clements
glynn at gclements.plus.com
Sun Jan 11 08:02:11 EST 2009
Moritz Lennert wrote:
> > Meschach is implemented in C and is able to replace the gmath library
> > completely with much better implementations.
> > I have integrated meschach into grass for testing purposes and, after
> > some very basic testing, it works nicely.
> > But im unsure if the licence of meschach is compatible with the GPL? Can
> > somebody please verify this? Im not an expert in licensing.
> This seems to be the relevant part:
> "The source code is available to be perused, used and passed on without
> cost, while ensuring that the quality of the software is not compromised."
> There is no mention of modification, and the second half of the sentence
> ("while ensuring that the quality of the software is not compromised")
> sounds quite suspicious to me. So, without claiming any expert knowledge
> either, I would be sceptical.
Where did you find that? It appears to contradict:
http://packages.debian.org/changelogs/pool/main/m/meschach/current/copyright
** This Meschach Library is provided "as is" without any express
** or implied warranty of any kind with respect to this software.
** In particular the authors shall not be liable for any direct,
** indirect, special, incidental or consequential damages arising
** in any way from use of the software.
** Everyone is granted permission to copy, modify and redistribute this
** Meschach Library, provided:
** 1. All copies contain this copyright notice.
** 2. All modified copies shall carry a notice stating who
** made the last modification and the date of such modification.
** 3. No charge is made for this software or works derived from it.
** This clause shall not be construed as constraining other software
** distributed on the same medium as this software, nor is a
** distribution fee considered a charge.
The latter is compatible with the GPL, the former certainly isn't.
