[GRASS-dev] gmath and gpde update
Moritz Lennert mlennert at club.worldonline.be
Sun Jan 11 16:32:26 EST 2009
On 11/01/09 14:02, Glynn Clements wrote:
> Moritz Lennert wrote:
>>> Meschach is implemented in C and is able to replace the gmath library
>>> completely with much better implementations.
>>> I have integrated meschach into grass for testing purposes and, after
>>> some very basic testing, it works nicely.
>>> But im unsure if the licence of meschach is compatible with the GPL? Can
>>> somebody please verify this? Im not an expert in licensing.
>> This seems to be the relevant part:
>> "The source code is available to be perused, used and passed on without
>> cost, while ensuring that the quality of the software is not compromised."
>> There is no mention of modification, and the second half of the sentence
>> ("while ensuring that the quality of the software is not compromised")
>> sounds quite suspicious to me. So, without claiming any expert knowledge
>> either, I would be sceptical.
> Where did you find that?
http://www.netlib.org/c/meschach/readme
> It appears to contradict:
> http://packages.debian.org/changelogs/pool/main/m/meschach/current/copyright
It definitely does. I would tend to trust Debian more than the above...
Moritz
