[GRASS-dev] Re: [GRASS GIS] #419: cairo compilation error
trac at osgeo.org
Mon Jan 12 10:47:20 EST 2009
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-32
Comment (by mlennert):
Replying to [comment:6 glynn]:
> Replying to [comment:5 mlennert]:
> > svn update and recompile now gives only one error:
> /home/mlennert/SRC/GRASS/grass_trunk/general/g.cairocomp/main.c:118:
undefined reference to `cairo_xlib_surface_get_xrender_format'
> make: *** [/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
gnu/bin/g.cairocomp] Error 1
> > Using cairo 1.4.14 on Debian stable.
> Right; I can only fix this in the sense of adding a configure check for
cairo_xlib_surface_get_xrender_format() and not building g.cairocomp if
it's missing. g.cairocomp can't work without that function, but the cairo
driver can.
And do I understand correctly that g.cairocomp is need to use the GUI, at
least when using the default cairo driver ?
I guess it's time to compile a more recent version of cairo, then...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:7>
