[GRASS-dev] Re: [GRASS GIS] #419: cairo compilation error
GRASS GIS trac at osgeo.org
Tue Jan 13 15:58:29 EST 2009
  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  7.0.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:7 mlennert]:
 > And do I understand correctly that g.cairocomp is need to use the GUI,
 at least when using the default cairo driver ?
 No. At present, g.cairocomp isn't used.
 Using the cairo driver to generate X pixmaps which can be composited by
 g.cairocomp offers a faster alternative to using PNM files, but it
 requires X, the XRender extension, and a recent version of cairo built
 with X and XRender support. Even if/when the GUI does use g.cairocomp, the
 use of PNM files will still need to be retained as a fallback.
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:8>
