[GRASS-dev] latest change in v.surf.bspline breaks it on a Mac
Markus Neteler
neteler at osgeo.org
Tue Jan 13 03:48:12 EST 2009
On Tue, Jan 13, 2009 at 5:53 AM, Michael Barton <michael.barton at asu.edu> wrote:
> I just updated develbranch_6 svn and compiled. v.surf.bspline will no longer
> compile. Lots of errors (or the same error many times.
> See below
> Michael
> cmb-MBP-2:v.surf.bspline cmbarton$ cd
> /Users/cmbarton/grass_dev/grass6_src/vector/lidar/v.surf.bspline
> cmb-MBP-2:v.surf.bspline cmbarton$ make
> gcc
> -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/include
> -arch i386 -Os -I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers
> -DPACKAGE=\""grassmods"\"
> -o OBJ.i386-apple-darwin9.6.0/main.o -c main.c
> main.c: In function 'main':
> main.c:358: error: syntax error before '<<' token
this indicates that patch mess in the file. Since
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c#L358
does not show any related problems it will be a local
problem on your system (did you have local, unsubmitted
changes?).
Delete file + svn up should solve it.
Markus
