[GRASS-dev] latest change in v.surf.bspline breaks it on a Mac
Michael Barton michael.barton at asu.edu
Tue Jan 13 09:52:04 EST 2009
That fixed it. Thanks.
Michael
On Jan 13, 2009, at 1:48 AM, Markus Neteler wrote:
> On Tue, Jan 13, 2009 at 5:53 AM, Michael Barton <michael.barton at asu.edu
> > wrote:
>> I just updated develbranch_6 svn and compiled. v.surf.bspline will
>> no longer
>> compile. Lots of errors (or the same error many times.
>> See below
>> Michael
>> cmb-MBP-2:v.surf.bspline cmbarton$ cd
>> /Users/cmbarton/grass_dev/grass6_src/vector/lidar/v.surf.bspline
>> cmb-MBP-2:v.surf.bspline cmbarton$ make
>> gcc
>> -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/
>> include
>> -arch i386 -Os    -I/Library/Frameworks/GDAL.framework/Versions/1.6/
>> Headers
>>   -DPACKAGE=\""grassmods"\"
>> include
>> -o OBJ.i386-apple-darwin9.6.0/main.o -c main.c
>> main.c: In function 'main':
>> main.c:358: error: syntax error before '<<' token
> this indicates that patch mess in the file. Since
> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c#L358
> does not show any related problems it will be a local
> problem on your system (did you have local, unsubmitted
> changes?).
> Delete file + svn up should solve it.
> Markus
